August 28, 20233 yr I was just wondering if Enpass on Android is expected to work with Microsoft Edge beta browser? I've just been using it for a few things and I've noticed that Enpass is almost never appearing an an option on the keyboard when I'm clicking in username and password fields on websites. This obviously all works fine with the 'release' version of Edge on Android. I'm seeing this same behaviour on multiple devices: Samsung Galaxy S22 phone (Android 13) and Samsung Galaxy Tab S5e (Android 11), with Enpass 6.9.1.844 I am specifically referring to the beta version of Edge which is available here - https://play.google.com/store/apps/details?id=com.microsoft.emmx.beta - as opposed to Dev or Canary versions. I completely understand if the position is that Enpass isn't tested with beta versions of browsers. Still, I wanted to ask the question and raise the point in case you wanted to investigate why it isn't working in case you need to prepare for a future release.
August 28, 20233 yr Author Oh, when it does work, its never able to match the website domain. I always have to search for the card in Enpass and confirm the match.
August 28, 20233 yr Hi @Anthony We appreciate your effort in bringing this matter to our attention. Your feedback has been duly acknowledged and relayed to our committed team for prospective enhancements. Meanwhile, we kindly request you to activate the "Autofill using Accessibility services" feature via the Enpass App Settings -> Autofill. This will facilitate autofill functionality on the Edge beta browser. #SI-3456
August 28, 20233 yr Author Thanks @Abhishek Dewan I'm finding that using accessibility services autofill is working on my Samsung S5e tablet (Android 11) but not on my Samsung S22 phone (Android 13). On my tablet I get the Enpass popup when I give focus to a username or password field, but nothing on my S22 phone.
August 29, 20233 yr Hi @Anthony While I have acknowledged the problem and escalated it to the appropriate team, it's important to consider that beta builds could potentially have some issues. As a temporary solution, you can utilize the Enpass keyboard for autofill specifically on this browser.
August 30, 20233 yr Author Interestingly, it seems that Enpass is treating Edge Beta as an app, rather than a browser. Every time I go to login to a site, Enpass isn't seeing a website domain in a browser. When I search for a card to use for username and password,, it always asks if I want to associate that card with "Edge Beta". I.e. it is treating it as an app.
August 31, 20233 yr Hi @Anthony We appreciate you sharing the feedback regarding this matter and have also have duly noted your comments.
