November 19, 20233 yr Dear support, While it is awesome to now have Passkey support - thank you. I just realized that Enpass incorrectly reports sites as missing 2FA, while Passkey is configured. Passkey should count as a second factor IMHO Enpass should even propose to activate passkey on services that support it (i.e. something like Passkeys.directory) Edited November 19, 20233 yr by FuN_KeY
November 20, 20233 yr Hi @FuN_KeY Please share the below details and I will get this further investigated for you - The version of the Enpass app and OS you are using. The URL of all the webpages on which you are facing this concern.
November 21, 20233 yr Author Version is the only one that yet supports passkey: 6.9.2 for Windows 11 URL is Uber - as shown in the capture
November 22, 20233 yr Hi @FuN_KeY Thank you for sharing the requested details. I'm discussing this case with our dedicated team and will get back to you soon with an update. Your patience and cooperation in the meantime are appreciated. #SI-3551
November 24, 20233 yr Hi @FuN_KeY We successfully reproduced this glitch and have recorded an enhancement for this scenario. This improvement will be integrated into upcoming Enpass versions. We thank you for your patience in the interim.
