November 27, 20233 yr Hi, When the Enpass Extension is installed in Safari, It is no longer possible to access the tinyMCE editor. You can check it on this page: https://www.tiny.cloud/docs/tinymce/6/full-featured-premium-demo/ The editor does not finish loading and cannot used. Several errors are visible in the console. Tested on Safari Mac 17.1, MacOS 13.6.1
November 28, 20233 yr Hi @dynweb Please share the version of the Enpass app you are using along with a screenshot of any error/short video of the issue and we will gladly get this checked for you. You can share the video with us at support@enpass.io and mention this forum.
November 29, 20233 yr Author Sorry, forgot to mention: Enpass + Safari Extension 6.9.2. Please have a look at the following video: https://monosnap.com/file/iZPIYOkmF8qV6IPvFhA5VXKhEB9vp4 Trying to load the tinyMCE demo from https://www.tiny.cloud/docs/tinymce/6/full-featured-premium-demo/ with Safari, Enpass Extension activated It won't load Disabling Enpass Extension (it was the only extension activated) Reload tinyMCe demo: working Trying to re-enable Enpass Extension: Safari error message Hope this helps Regards
November 30, 20233 yr Hi @dynweb Thank you for sharing the requested details. I'm discussing this case with our dedicated team and will get back to you soon with an update. Your patience and cooperation in the meantime are appreciated. #SI-3559
December 5, 20232 yr Hi @dynweb Upon a thorough discussion and investigation, we were able to reproduce the bug. Our development team is now working on fixing it as a priority, and a patch addressing this issue will be released soon. We appreciate your kind patience and cooperation in the interim.
January 14, 20242 yr Hello, what about the patch for this problem? It's really annoying that you have to deactivate Enpass on websites with TinyMCE in order to use it. - Enpass 6.10.0 - Safari 17.2.1 - MacOS 14.2.1 Edited January 21, 20242 yr by WurzelGnOOm
February 13, 20242 yr Hello, Is there already a solution for this problem? The current beta version doesn't really improve the situation. - Enpass 6.10.0 - Safari 17.3.1 - MacOS 14.3.1 on Apple M3 Ultra
February 14, 20242 yr Hey all, As updated, the issue has been successfully reproduced at our end, and we are still working on a fix, in the upcoming builds. As of now, no ETA has been provided. We appreciate your patience in the meantime.
April 11, 20242 yr Hi everyone, I have the same problem with Confluence (which uses TinyMCE as editor, as I understood). Are there any news on the fix? If I deactivate the extension for this specific URL, the Enpass icon gets greyed out, but the error is still there. The only way to get it working is to completely remove the Enpass extension, which is not suitable for daily work. Thank you! Details: Enpass 6.9.5 (Mac App Store) Safari 17.4.1 MacOS 14.4.1
April 11, 20242 yr Just adding a +1 on this issue as I've just discovered it with a slightly different platform combination MacOS 12.7.4 (I know ;-) Safari 17.4.1 Enpass 6.9.5 (1640) Mac App Store A couple of observations in case they help you debug: The tinymce instance will sometimes initialise, but then the content within it's embeded iframe appears to be wiped after being initialised. If there are multiple TinyMCE instances on a single page one will load, but subsequent ones will not initialise. To me this would point to Enpass trying to detect the content type of the field and blocking for some reason. But that's just a wild guess!
April 12, 20242 yr I am glad to inform you that, Our development team has created a fix for issue you were , which will be included in the Upcoming updates. We appreciate your patience in the meantime.
August 6, 20242 yr Hallo, That is good news. V.6.11 doesn't have the fix yet. Do you have any information for us when the problem fix will be released?
