March 1, 20242 yr LinkedIn used to provide a link to login with passkeys, worked fine with Enpass. Now they (LinkedIn) changed the flow so that a floating popup appears, reading 'login using key', when focusing on the username or password-field. That popup however brings up Windows native login-screen (device, pin etc) and bypasses Enpass' Passkey-integration. If more sites follow this, you might have a growing issue at hand. For Edge and Firefox, i dont event get that floating popup at all. Windows 11, 23H2. Google Chrome: 122.0.6261.70 Enpass (Microsoft Store): 6.9.4 (1630) Enpass Chrome-plugin: 6.9.3
March 1, 20242 yr Thank you for sharing the details and your efforts in providing information. I've reported this issue to the Enpass technical team. They are currently investigating it, and I will reach out to you with updates as soon as I receive them. #SI-3696
August 13, 20242 yr Author Any news on this @Amandeep Kumar? Also tried on: Kali Linux Enpass 6.10.1 Chrome 127.0.6533.99 Still doesn't work. I was able to create a PassKey in Enppas for Android android, but obviously can't use it on desktops. Is LinkedIn enforcing hardware-bound passkeys that Enpass is unable to process?
