March 7, 20242 yr Hi, is there any option to host the vault at my own server? Option 1 i found: use wifi sync, this is no option for me, i wont use my desktop pc to run as a server cause he is not running all the time is the maybe an way to host this "wifi sync" server in docker? i will sync between windows, iOS, MacOS and in the future maybe on linux. has anyone a good idea to use an existing fileserver and docker to get this work? greetings (im new, be kind) Edited March 7, 20242 yr by Dingersen
March 7, 20242 yr Author WebDAV is no Option. i wont put holes in my system. it is not rational to use webdav only for lokal porpose, if there is a fileserver and mapped drives. but thanks for the hint
