How to Sync Enpass on PC. ----------- FIXED
Syncing IPhone 15 to PC
I can sync Enpass to my IPhone 15 to Google Drive.
I can not find the menu to sync Enpass on my PC to Google Drive.
Anyone assist or any other way to sync an IPhone and PC.
Edited by Col
  • Col changed the title to How to Sync Enpass on PC.
To sync a Enpass vault,  on your PC with Google Drive, please follow these steps:
  1. Open the Enpass app on your PC.
  2. Navigate to the settings or preferences section. This is usually represented by a gear icon or similar.
  3. Look for the "Vault"  option in the settings menu.
  4. Then select vault that you want sync with google drive.
  5. Then click on connect.
  6. Select Google Drive as your preferred cloud storage provider for syncing.
If you're still experiencing the issue, please provide the following details:
  • Enpass version.
  • Operating system version.
  • A screenshot of the Enpass settings under "Vault > Connect > Options" where you're encountering the problem.
Thanks for your reply.  Much appreciated.
I have been doing what you said but the menu on Google Apple etc would not come up.  I logged on to my wifes PC and it worked.  So I noticed mine showed with WiFi sync that I was synced with a IP address.
So I had to stop that and then go into Vault as you said, the options including Google was there.  So now it works.
Thanks again.
  • Col changed the title to How to Sync Enpass on PC. ----------- FIXED
