June 6, 20188 yr Enpass Extensions are not working. It happens in every browser. I already reported this issue in enpass support. Till now there is no reply from them. Please help me.
August 24, 20188 yr It doesn't work for me either. Operating System : Linux (Ubuntu 16.04) Browser: Firefox Quantum (61.0.1 (64-bit)) lsof result: COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME Enpass 9009 ipkiahme 30u IPv4 103963 0t0 TCP localhost:10391 (LISTEN) Enpass 9009 ipkiahme 32u IPv4 103976 0t0 TCP localhost:10391->localhost:40854 (ESTABLISHED) EnpassHel 15709 ipkiahme 20u IPv4 107067 0t0 TCP localhost:40854->localhost:10391 (ESTABLISHED) It seems to work with Google Chrome, but Firefox one keeps saying "Connection Error" Edited August 24, 20188 yr by Ahmet Ipkin Browser updated
August 27, 20188 yr Hi @Ahmet Ipkin Sorry for the trouble you're going through. I would like to share that Native messaging host for Enpass is an additional component which is required to connect the Enpass app with the Firefox WebExtension through native messaging. But as I can see in the attached logs Native messaging host is not running that's the reason it displays the Connection error. I would suggest you; please try re-enabling the browser extension option from Enpass Browser settings. If the problem persists, share the version of Enpass app and extension you are using so that we can look into it.
September 24, 20188 yr Hello I've tried enabling and disabling the extension but still doesn't work. Enpass version 5.6.9 Browser extension: Enpass Password Manager 5.5.2 Edited October 8, 20188 yr by Ahmet Ipkin browser extension updated
October 8, 20188 yr By the way, the Chrome Browser can successfully use the extention, no problems there although Firefox still doesn't work. Any update on this?
October 8, 20188 yr Hi @Ahmet Ipkin Sorry for the inconvenience. We have tested this issue in our lab with the same OS version and everything works fine. To investigate further in this issue, please follow these steps and share your findings. Go to Home Folder--> Press Ctrl+H (to unhide hidden files) --> Open .mozilla folder --> And check if the native-messaging-hosts folder is exists --> And inside that folder EnpassNMHost.json file exists and have Read and Write permission. Also, run the following command in the terminal and share the output. /opt/Enpass/bin/EnpassHelper/runNativeMessaging.sh Thanks for your co-operation.
October 18, 20188 yr Hi @Anshu kumar, trying to get the Enpass extension to work with Firefox under Linux, I face the same issue. I can confirm that the file .mozilla/native-messaging-hosts/EnpassNMHost.json exists on my machine, is world-readable and that the path in the file is correct. I can also confirm that EnpassHelper is successfully started by Enpass, and I can see a EnpassNMHost process for some time. So at first glance, everything looks fine, however I get the Enpass Connection Error when clicking on the icon. What I noticed, which might be helpful: when I start firefox from the commandline, I can see this error message being printed: JavaScript warning: moz-extension://d35a2cae-4679-4b23-bc27-df6cda4eeeef/data/commonJS/sodium-asmjs.js, line 0: Successfully compiled asm.js code (loaded from cache in 1582ms) JavaScript error: moz-extension://d35a2cae-4679-4b23-bc27-df6cda4eeeef/data/commonJS/sodium.js, line 1: TypeError: NetworkError when attempting to fetch resource. This seems to be coming from the Enpass extension, AFAICT... Clearing the directory .mozilla/firefox/*.default/storage/temporary/moz-extension+++d35a2cae-4679-4b23-bc27-df6cda4eeeef/ did not change the behavior, neither did creating a managed-storage JSON... Gentoo Linux amd64, Firefox 62, Enpass 5.6.9 with browser extensions enabled, Enpass Extension 5.5.2.
October 18, 20188 yr I did check the files - it is there and has Read and Write permission for my user (644) and the command you told outputs this result: �"wXLrXGGjLYpNIlPpwZKhF+GPQ7UnKiY8dLjSK7y0j8ttejcOHlUmvq2ptzA6qlVuIv34+Ebzrt+hTTwhy0C0Ym8PwKh1Mvn/y/NO5MQG03+O9W2JuIc3gtRbZPByPhpo"
October 31, 20188 yr I see these messages in the error console when I try to debug it: Quote Unchecked lastError value: Error: Could not establish connection. Receiving end does not exist. Could it be that you're hitting to this bug? https://stackoverflow.com/questions/47066984/getting-could-not-establish-connection-receiving-end-does-not-exist-when-con I don't know if this is relevant. Edited October 31, 20188 yr by Ahmet Ipkin
