Password filling for both Username and Password on Pixel 7 Pro at https://reg.usps.com
This is happening on my Google Pixel 7 Pro:
Android  - Version 14 Build AP1A.240405.002
Microsoft Edge for Android browser - 123.0.2420.102
Enpass - 6.10.1.982
Works fine on my Windows 11 desktop running Edge Browser.  This just started happening a couple of days ago and I can't trace back a specific update.
Thank you for sharing the details and your efforts in providing information.  I've reported this issue to the Enpass technical team. They are currently investigating it, and I will reach out to you with updates as soon as I receive them.
#SI-3807
Bug for the respective issue has been logged. The fix will be provided in an upcoming release. We'll keep you updated on the progress and let you know once the fix is available.
  • 2 months later...
Our development team has created a fix for the issue you were facing, which will be rolled out in future release. We appreciate your patience in the meantime.
  • 2 months later...
Hello, there's been a couple of releases and this issue is still present.  Any update you can provide is greatly appreciated.  Thank you.
  • 4 months later...
Hello,
You indicate that there is a fix for this and that it will be rolled out in a future release.  Is there an ETA on the roll out?
Thank you for any update you can provide.
  • 2 weeks later...
