May 22, 20242 yr Hallo, habe mein Enpass Backup auf dem Mac erfolgreich zurück gesichert. Wenn ich jetzt die Synchronisierung mit Google Drive mache, werden alle Daten wieder gelöscht.
May 30, 20242 yr To ensure your data isn't deleted when you sync with Google Drive, please follow these steps: Make sure you have a secure backup of your Enpass data stored locally on your Mac. On your Enpass app, go to the sync settings and disable any existing sync with Google Drive or any other cloud service. Log into your Google Drive account and check the Enpass folder. If there are any old or corrupted sync files, consider removing them to avoid conflicts. Go back to your Enpass app and re-enable the sync with Google Drive. When prompted, select the option to merge data rather than overwrite to ensure your current data is combined with the data on Google Drive. By following these steps, you can avoid data deletion and ensure that your Enpass data is safely synced across your devices. If you continue to experience issues, please provide more details or screenshots so we can assist you further.
