May 29, 20242 yr Hello, i try to run Enpass under Linux Mint 21, but after every restart of the system, Enpass has forgotten the configuration (Sync-Mode, Tresor etc) and starts the configuration process from new ("Enter Activation Code" and so on). What can i do? Any help is welcome Regards Frank
May 30, 20242 yr To resolve Enpass forgetting its configuration on Linux Mint 21, try the following steps: 1.Ensure Enpass has the necessary permissions to read and write its configuration files. 2.Verify that the configuration files are stored in a persistent directory like `~/.config/Enpass`. 3. Ensure the files and directories are owned by your user and have the correct permissions. Use: ```bash sudo chown -R $USER:$USER ~/.config/Enpass sudo chmod -R 700 ~/.config/Enpass ``` 4.Sometimes a fresh install can resolve configuration issues. Backup your data, uninstall Enpass, and then reinstall it. If issues persist, consider reaching out to Enpass support at support@enpass.io for further assistance.
May 30, 20242 yr Author Hi, i created the folder ~/.config/Enpass (why not created at installation?) and set access and ownership like you mentioned above. After that, i un- and reinstalled enpass (with the appmanager of Linux Mint as Flatpak) and set the configuration. But nothing is stored in ~/.config/Enpass (and no error message is coming up), same behaviour after restart: Enpass wants to set a new configuration. As you suggested, i wrote a mail to support@enpass.io. Regards Frank
May 31, 20242 yr Author Hi, found it. The reason for this problem was that i've installed enpass with the App-Manager of Linux Mint as Flatpak. After i've deinstalled this version and reinstalled in a console window (following the instructions on the enpass website), it runs like a charm. Funny fact: The problem i've described in this posting is also gone, all folders are shown. Thanks. Best regards Frank Edited May 31, 20242 yr by Dominion
