August 23, 20242 yr Having just imported about 500+ entries from Pleasant Password Server and about 400+ entries from Bitwarden, I'm missing an option to apply a Template to an existing entry. I have to manually align the imports to have the fields I'd like to use and remove tons of fields, I don't need, but the old system has exported with empty content. Userstory: When applying a template, the system should remove all unused fields that are not also contained in the Template; obviously, all missing fields from the Template should be added. This would save a lot of time when moving from old structures.
August 28, 20242 yr I am raising this issue with our technical team as a feature request, and we may consider adding it in our future updates. However, please understand that several factors and considerations have to be taken into account. #SI-3973
