August 29, 20242 yr Has anyone tested if using Enpass for Linux on ChromeOS Flex works across the whole OS? Putting Flex on my laptop and missing my password manager on it is going to be a pain.
September 3, 20242 yr Enpass for Linux should generally work on ChromeOS Flex, but compatibility can vary depending on the specific setup and how ChromeOS Flex interacts with Linux applications. To better understand your concern, could you please share more details about the issue you're facing? If possible, include any screenshots or error messages you encounter. This will help us provide more targeted assistance and find a solution that works for you.
October 12, 20242 yr On 8/30/2024 at 12:07 AM, IGS said: Has anyone tested if using Enpass for Linux on ChromeOS Flex works across the whole OS? Putting Flex on my laptop and missing my password manager on it is going to be a pain. Can confirm it works. The browser extension won't connect to the desktop app however. Desktop app gets opened, but extension says "Enable autofill service", which I enabled ofc. Any solution for this @Amandeep Kumar?
October 15, 20242 yr Currently, Chrome OS Flex does not support Android apps or Google Play. However, we have noted your feedback and forwarded it to our technical team for consideration in future updates. Please keep in mind that various factors and considerations will be taken into account as we explore this possibility.
December 17, 20241 yr Can comfirm too, that Enpass can be installed as a normal Linux Desktop App in Chrome OS Flex Linux Developer-Environment VM. You can use the normal installation procedure for Linux described here: https://support.enpass.io/app/getting_started/installing_enpass.htm
