September 9, 20242 yr Hi there, I am trying to export a CSV file from Enpass. However, the exported CSV file does not have any column titles. Can someone help by providing a template of column titles which I can add as an addiitonal row in the exported CSV file? Thanks!
September 12, 20242 yr To better assist you, could you please elaborate a bit more on the issue you’re facing? Specifically, let us know which Enpass version you are using. This will help us provide you with the most accurate template of column titles that matches your export format.
September 25, 20242 yr The issue comes from the formatting used in Enpass' CSV export format. Most apps look for columns at the top that describe what the column information is. Enpass is missing this information, making it impossible to import it's information to other apps, like Google Password Manager, 1Password, ETC. This needs to change.
September 30, 20242 yr I am submitting this issue to our technical team as a feature request, and we will evaluate it for future updates. Please note that we must consider various factors in the decision-making process. #SI-4042
