September 30, 20242 yr macOS Sequoia + Safari 18 allows installed extensions to be enabled in WebApps created via Safari's Add to Dock feature. This would be quite useful for the Enpass Safari extension. Currently, the Enpass Safari extension doesn't appear in the list of available extensions in a WebApp created via Safari's Add to Dock feature. One extension which does seem to work is called Userscripts - an open-source extension distributed via the Mac App Store. Please see attached screenshot for reference.
October 13, 20242 yr I've reported this to the technical team. They are investigating it, and I will reach out to you with updates as soon as I receive them. #SI-4065
