Hello,
When I try to load a small attachment (just a few kb) into Enpass I get a warning:
Attachments must be smaller than 5 MB.
The attachment will then not be loaded
Am I doing something wrong or is this a bug on Enpass's part?
Hello and thank you for your answer,
1. Enpass 6.11.8 on Mac OS 12.7.6
2. File type is RTFD (see attachmant)
Right now I found my mistake by myself. The file type was RTF. If I make a PDF out of the RTF, Enpass will import it. I assume you cannot import RTF.
