Convert the Enpass repo entry to DEB822
Debian starts to switch to the DEB822 format (Sid)
I use Testing.
I have already converted the Debian and some other repos.
According to this scheme, the entry for enpass should read as follows:
Types: deb
URIs: https://apt.enpass.io/
Suites: stable
Components: main
Enabled: yes
Signed-By: /etc/apt/trusted.gpg.d/enpass.asc
I saved this in
/etc/apt/sources.list.d/enpass.sources.
apt update does not produce any error message
OK:6 https://apt.enpass.io stable InRelease
from apt-listchanges:
Quote
/etc/apt/trusted.gpg is no longer trusted.
Setting the Dir::Etc::trusted
option manually continues to work for some more time.
It would be nice if you could publish a gpg key for  /usr/share/keyrings
Edited by geier
  • 10 months later...
Here's what I use for the enpass.sources in /etc/apt/sources.list.d. I am assuming that you create the key in /etc/apt/trusted.gpg.d/enpass.asc
Types: deb
Suites: stable
Components: main
Architectures: amd64
Afterward, you can do a sudo apt update and then sudo apt install enpass.
If the enpass team can test it out and update their instructions.
Thanks for sharing these details and the configuration you’re using. We’ve shared the steps with team for review and verification, and they’ll evaluate updating the official instructions accordingly.
Appreciate you taking the time to document this.
  • 1 month later...
You should be honest enough to admit that there is no longer a technical team.
The DEB822 issue has been known here for a year.
There has been no change.
Nor the question about a valid key for the repository.
Same old story: It gets reported to whatever team, blah blah blah.
See here: https://discussion.enpass.io/index.php?/topic/31740-policy-will-reject-signature-within-a-year/
Now the situation is such that you can no longer install Enpass from the repository and you don't receive any updates.
Edited by geier
