March 31, 20251 yr I purchases the Premium Enpass Version in a One Time Buy, im new to the Term of Passwordmanagers. Enpass created a Vault on my Mac Computer at the Documents Folder. It would be better, to Transfer the Vault to Onedrive, so i could everytime Sync it with Iphone oder Samsung Android Phones. Today i Use a Synology Nas, but in Future i wont use it, because i only Store 400mb of Word Documents on it, its oversized for me. I created a WEBDav on my NAS, so it syncs successfull with my Iphone and Android Phone. But in Future, i like to have the Vault in Microsoft Onedrive and i like to sync the Word with Smartphones via Onedrive. Is that possible? I tried to Copy and Paste the Vault on my Synology NAS, but then all Passwords, was deleted, as i copied it back on my Mac in der same Documents Folder, the Passwords were back. How could i solve this?
March 31, 20251 yr Hi there, this is no issue at all, try following this steps, they should work almost identical to what you need. https://discussion.enpass.io/index.php?/topic/31585-clean-install/#findComment-91490 Also after you've done the backup, go into your vault and click disconnect. Afterwards if you click Connect you can choose a new location to sync to from your PC, therefore changing it's default Cloud Sync. Hope this helps.
