April 8, 20251 yr I have installed Enpass on a new Macbook Air with MacOS 15.4. I also have installed the Safari extension. Everything seems to be OK. I also synced all my passwords. However, the autofill popup menu won't appear when I want to enter username/password on a website. I looked in the support files (https://support.enpass.io/app/extension/take_a_look_at_browser_extension_settings.htm#autofill-popup-menu) but I can't find the settings screen which is described there. Am I overlooking something? Note: I have Enpass running on my Mac Mini (with MacOS 15.4) and before that on my iMac without problems. On these machines the autofill popup menu appears always. Edited April 8, 20251 yr by lexvo
April 8, 20251 yr Author I found the place where I have to flip a switch to turn autofill on. Problem solved.
July 9, 20251 yr On 4/8/2025 at 8:56 PM, lexvo said: I have installed Enpass on a new Macbook Air with MacOS 15.4. I also have installed the Safari extension. Everything seems to be OK. I also synced all my passwords. However, the autofill popup menu won't appear when I want to enter username/password on a website. I looked in the support files (https://support.enpass.io/app/extension/take_a_look_at_browser_extension_settings.htm#autofill-popup-menu deltarune) but I can't find the settings screen which is described there. Am I overlooking something? Note: I have Enpass running on my Mac Mini (with MacOS 15.4) and before that on my iMac without problems. On these machines the autofill popup menu appears always. Glad you figured it out! Sometimes those little settings can be easy to overlook—thanks for the update, this might help others with the same issue.
