April 12, 20251 yr I have enabled auto backups and they do occur but I can't figure out the frequency or trigger. I couldn't find it in the manual. Some days there are multiples, other days none, so it's not daily. I tested deleting an entry and editing another, thinking any vault change might trigger it, but that didn't do it. Can anyone enlighten me? Thanks! Edited April 12, 20251 yr by BataviaJim Add omission
May 27, 20251 yr I wanted to clarify how Enpass auto backups work and their triggers: Auto backups occur based on tracked user actions categorized as major and minor events. When certain thresholds are met (major counter = 3 or minor counter = 6), an auto backup is triggered, with a maximum of one auto backup per day. Other backup types (Erase, Import, Change Password, Restore, Manual) occur at specific actions like erasing data or changing passwords and can happen multiple times a day. A total of 60 backups are maintained, with auto backups replacing older ones once limits are reached.
