April 28, 20251 yr Hello my Vault syncing to OneDrive is failing across Windows, MacOS, iOS, iPadOS and Android OS. I have attached a screen shot of the failure message on Windows for reference and have confirmed the same message with error code is in all previously mention platforms
May 2, 20251 yr Please disconnect the sync between your Enpass vault and Onedrive, then reconnect it and check if the issue is resolved.
September 8, 20251 yr On 5/2/2025 at 7:05 AM, Tarun Singh Rawat said: Please disconnect the sync between your Enpass vault and Onedrive, then reconnect it and check if the issue is resolved. Hi. I am having the same issue (error code 1204958 when syncing to Onedrive) with Enpass for Windows (6.11.14 2056) and Android (version 6.11.12.1147). I have disconnected the sync between Enpass vault and Onedrive, then reconnected it, but the issue remains. Any other suggestion?
September 8, 20251 yr I'm having the same issue with vault syncing on OneDrive with error code 1204958 (on Android and Pop OS), but after extensive troubleshooting I checked the Microsoft service dashboard and saw that OneDrive is currently having issues: https://status.cloud.microsoft/m365/ Might need to wait until those clear up before attempting to fix the Enpass sync.
September 9, 20251 yr Thank you @xbolte, I should have checked that before posting. The MS service has been restored and Enpass sync is now working.
September 9, 20251 yr This issue was caused by a temporary glitch on Microsoft’s end, and it has now been resolved.
