July 21, 20251 yr I have the portable version of enpass installed at work. It is not syncing. When I disconnect and reconnect, I get this Then set up sync spins
July 22, 20251 yr We’ve already escalated the sync issue with OneDrive on the portable version of Enpass to our Product Team. They are actively working on identifying the root cause and implementing a fix. We appreciate your patience and will keep you updated as soon as we have more information. #SI-4235
