WebDAV sync error code 7
I sent this to support, but received no response, so I'll try here. If nothing else this might serve as a warning to others who might see the same issue...
I've been using WebDAV sync on multiple machines without issue. However, I recently migrated one Enpass installation to a new Mac and WebDAV sync stopped working. In the UI I'm only told to "check my internet connection". Logs show:
Info: 1753071137 [Request Failed::]  Error Code: 7    Error
I have disconnected the sync and attempted to reconnect with the same error. Ignoring SSL certificates appears to make no difference. I can access the WebDAV path with a browser (Firefox) using the same username and password.
What does error code 7 indicate? Several other Macs are working with this server without issue.
