October 17, 20251 yr I'm fine with the inline icon that appears in the form field on a webpage provided by the browser plugin. But is it possible to get rid of the large blue dropdown that appears? It's big, obnoxious, unnecessary, and gets in the way. If not, please add this as a feature request for the browser plugin settings as an option to disable.
October 22, 20251 yr I discussed this with our technical team, and unfortunately, Enpass does not currently have an option to disable the large blue dropdown from the browser plugin. We truly appreciate you bringing this concern to our attention. I have submitted this as a feature request to our technical team for consideration in future updates. Please understand that several factors need to be considered before any changes can be implemented. Thank you again for your understanding and patience. #SI-4546
