Selectively disabe"Autofill with Enpass"?
Hello. Is there any way to disable the "Autofill with Enpass" pop-up bubble on specific apps without disabling it completely? For several months now, it constantly pops up over my DuckDuckGo search box, and it has become terribly annoying.
Thank you for any suggestions.
You can disable the “Autofill with Enpass” popup on specific apps or websites without turning it off completely.
To manage this, you can use the Inline Autofill Popup Menu blocklist inside the Enpass browser extension settings:
How to disable the autofill popup for specific sites
  1. Right-click the Enpass extension icon in your browser’s toolbar.
  2. Select Settings.
  3. Use the Show Inline Autofill Popup Menu toggle to enable/disable the popup globally.
  4. To hide the popup only on certain websites:
    • Scroll to Inline Autofill Popup Menu blocklist
    • Enter the website URL you want to block in the Add URL field
    • Click Add
    • (To remove a site later, click the ✖ next to the URL.)
Now the popup will be suppressed only for the websites you add to this blocklist.
Thank you for your reply. However, I am referring to my Android tablet and phone, and DuckDuckGo web browser. There is no toolbar extension.
Currently, the Enpass app for Android does not allow disabling the Autofill popup for specific browsers or apps. I have shared your suggestion with our technical team for review, and they will consider it as a potential feature request. Please note that several factors need to be evaluated before any changes can be implemented.
#SI-3621
