June 14, 20188 yr I have selected in "Enpass 5" - Backup and saved it to my drive. In "Enpass 6" I select "Restore" and select the backup file. Now I am asked for my password. After a long time, about 30 seconds, I get the message "Incorrect password."
June 14, 20188 yr I found the same - but after restarting Enpass 6 the vault had been loaded correctly. However, also had on a couple of occasions Enpass 6 crashes at the end of the import - but again if you restart the app, the vault is loaded ... Windows 10 64bit [Version 10.0.17134.112]
June 18, 20188 yr I had the same problem. Also, Enpass6 apparently created multiple vaults for every try to enter the password:
June 18, 20188 yr Hey guys, Thanks for reporting these issues. We have tracked the issue and a fix will be available in the next update. Thanks for your co-operation and keep reporting.
