June 29, 20188 yr Hi, I have a strange issue with enpass. Enpass desktop (actual Version) is running on an win10 pc. Every time I will log into enpass desktop app, I must enter the password twice. The first input end every time in a login error …. it doesn’t matter if I enter the pwd with copy/past or normal with keyboard …. This is very annoying. I have this issue since the last versions of the desktop app. Is this a bug or a wrong installation? br rob
July 2, 20188 yr Hey @portboy Please let me know the keyboard layout that you're using along with the preferred system and Enpass languages so that we can investigate the issue. Thanks.
November 7, 20197 yr Hi, I have been having this issue recently. I am using Ubuntu 19.10 (although it was happening before I upgraded from 19.04) I use a us-dvorak keyboard layout (but have tested it with us-qwerty) and happens whether I use copy-paste, a yubikey, or an onlykey (both of which I am using to output a static password). I have tried playing with adding delays to the outputs on these devices and that doesn't seem to help, but it does happen a lot more when using my hardward keys than when copy-pasting. I have tried English NZ,US, and UK as system languages and all have the same problem.
November 11, 20196 yr Hi, I have been having the same issue except that I have to enter the master password 4 times.... Windows 10 with either Engish Canadian multi-language or Canadian multi-language, either typing or using copy/paste.... No change in the results. Hope you can find a cause for that, it's a bit annoying. Thanks, Pierre
