default fields
When we make a new Item there are already commonly used fields as default. for example UserName, EMail, Password, telephoneNumber, URL, security question.
Is there a way to edit the default fields. So that in future if I make a new item there are other fields by default?
Hi @Endru,
Thanks for writing in with your question. Support for custom templates is already in our roadmap and will be available in future version. Meanwhile you can use these steps:
  • Create and customize an item as your wish.
  • Right click on the item and select duplicate. For more details please have a look at our user manual.
Cheers!
