Use favicon images for logins with URLs
On 4/11/2019 at 10:48 PM, Vikram Dabas said:
Hi All,
The Favicon feature has already been added to the Enpass app. Please wait for the coming update v6.1 which will bring it. Thank you.
Where are the Favicon's????????????????
  • 4 weeks later...
  • Replies 63
  • Views 39.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Sahil Sharma
    Sahil Sharma
    Hi @DustinDauncey, Here we are planning to introduce a rich icon support for URLs and of course, our team is putting vast efforts to deliver the best. At the moment I can't confirm any ETA.
  • Mattchewie
    Mattchewie
    Coming from Safe-in-Cloud, the favicon option is the best. So I second this request. IIRC, if you don't want the favicon or if the site doesn't have one, you can just assign one of the built in icons
  • It would be great if when you create a login for a website that Enpass would use the icon from that website, instead of the ones that you have in the database.
Hi All,
have now v 6.1.1 (408) but no favicons.
Is there a special folder?
Found the location of the he known icons
Users/?????/Library/Containers/in.sinew.Enpass-Desktop/Data/Library/Application Support/Enpass/icons/item/
Same for me. Seems like Enpass recognise only few big websites like Apple, Airbnb, Facebook, Netflix, Twitch ....
Hi All!
I've purchased Enpass PC & Mobile and would also like to know more about adding a few new icons!
I have done a little experimenting and tried converting a png to the 3 sizes that are available within the enpass ITEM's folder.
20x20 40x40 120x120 they are all pngs.
I have copied them into the ITEMS folder "Misc" - I have tried giving them a similar name as the ones already in the folder e.g. 1.com.png, 1, 1.com@2x.png & 1.com@3x.png.
After a little more investigating I had also found 2 json files that contain web address info related to the relevant default pngs within enpass, now I am only assuming that IF one was to
want the Icon associated to the password info entered into enpass i.e. when entering your information,  and wanting a special new icon associated to that info, one would enter such
details into the json file similar to what has already been entered for previous icons i.e. default!
That only leaves one thing left?  where to I place my new icon/png?
Due to licensing, Conditions of use etc I will not attempt to edit Enpass to what it was originally designed for - I am not a Programmer nor an expert!
I will leave my comments here for Admin and the like to ponder over and possible include an option that can allow the user to add new icons at their leisure with zero impact on security.
Regards
  • 3 weeks later...
Signed up just to tell that I'm waiting for favicon feature too, hope someone will clarify roadmap here soon
Regarding custom icons, the procedure to add them is very easy.
They are stored within Enpass as 200x200 png files. In earlier versions, you had to convert the Icons to this size. in the meanwhile I noticed, that Enpass can do this by itself. You just have to select a square jpg or png and the upload this file (if the format isn't square, sometimes "strange" results will show up, where e.g. only parts of the icon are shown):
  • Select an entry and go to edit mode.
  • Click on the icon and see the dialogue "choose icon"
  • In the headline of this dialogue you will find a "+" sign on the upper right side.
  • if you click onto the "+" you can choose a file to be uploaded - search the file in your file system and "open" it.
  • Afterwards you will be able to select the new icon in the custom icon section
The Favicon function isn't implemented yet - it was part of some beta versions, but didn't find its way to the product version.
  • 3 weeks later...
On 8/15/2019 at 8:54 AM, Ernst said:
Thank You, very much indeed!
That helped. The icons are stored in the database and show up on any other device like iPad, Linux etc.
version 6.1.2 favicon not.
There is information when there will be automatic loading favicon?
  • 3 weeks later...
Hey guys,
Now the wait is over.
Recently we have rolled out the Website icons aka Favicons with Enpass v6.2, please update Enpass and share your findings.
In which resolution do you provide the Favicons on your server?
When I tried this feature I noticed, that there is small icon and a big white border around for e.g. Acronis Icon. This happens also with other Favicons. It seems, that the functions uses only 64x64 of the possible 200x200 pixels.
That's disappointing :(
I also wonder what happens if the server blocks the favicon for whatever reason, can we still manually select a generic icon or choose from the default Enpass icons?
Some sort of indicator of how many website icons are loaded out of how many entries would be good including a manual sync of the favicons otherwise we dont know how often or when Enpass checks of ricons and newer versions of the icons, if any.
Whilst a highly requested feature, it is not a very well explained feature at all.  If Enpass will connect to try 300 website icons on every startup or even periodically, some servers might respond as down and then through Enpass we have no idea of the progress or even a prompt.
