July 24, 20188 yr Hi Guys, please give us an option to AutoFill TOTP as well that will make the whole sign-in process more seamless. EDIT: Found an option which automatically copies TOTP after the login. I hope it's available on the Android App too. Edited July 24, 20188 yr by teja2495
September 24, 20188 yr Definitely need TOTP autofill for Android. Edited October 4, 20242 yr by ohgoodgravy
September 24, 20188 yr Hey guys, Thanks for writing in. I would like to share that the feature Copy TOTP after Autofill after autofill has already been implemented and will be available in the next major update Enpass 6. Cheers!
September 25, 20188 yr 20 hours ago, Anshu kumar said: I would like to share that the feature Copy TOTP after Autofill after autofill has already been implemented and will be available in the next major update Enpass 6. Sorry for a little OT: is the same feature planed for the iOS version of Enpass?
September 25, 20188 yr Hi @xarekate, Yes, same has already been implemented for the iOS platform. Cheers!
February 3, 20197 yr I still can't figure out how this works in IOS. Here are the steps I currently have to take: Click link in Enpass to launch a site. Enpass auto fills user name and password. Screen appears to enter 2 factor authentication code Exit screen with code field; open i Message app; copy code; return to screen with code field and paste in code. Is there a simpler way?
February 4, 20197 yr @DavidL There are some different ways to setup 2FA in general. Two of the most common are receiving a code via SMS and generating a code via some appropriate app, using a secret key. This are 2 different things and they have nothing in common. Enpass can handle only the 2FA generating a TOTP 6-digit code from a secret key, which you get from a website when you setup 2FA. If you're speaking about copying code from iMessage, so I suppose you've chosen the variant with SMS code and there is nothing you can manage with Enpass. You'd have to rerun the 2FA setup on that website and chose a different opportunity of creating the code (if possible at all, because some are offering SMS only 2FA). Only in that case TOTP autofill would work! Edited February 4, 20197 yr by xarekate
