August 15, 20188 yr So I currently use Enpass 5.6.19 with a personal OneDrive account synced. When I try to sync Enpass 6.0.0 (72) to the same OneDrive account, not all of the items get synced. I'm only seeing 3 out of the 13 items. It also appears that items I update or add are not synced between different versions.
August 16, 20188 yr Hi @lokdawg78, First of all, I would like to share that restoring Enpass 5 data directly from the cloud is not possible, you need to restore it with the backup file. Please follow these steps for restoring Enpass 5 data into Enpass 6. Step 1: Open Enpass 5 --> Take the backup of Enpass data and save it manually on the system. Step 2: Quit Enpass 6 (If running). Go to User Documents folder --> Rename Enpass6-Beta folder. Now Open Enpass 6. It will prompt you a welcome screen --> Select Backup file --> Browse to the backup of Enpass 5 and follow the instructions. Hope this helps!
September 7, 20188 yr Hi, I'm lost on step 1 1) I open Enpass5 2) go to settings 3) Choose Backup and Restore 4) imidiatly openswindow with wifi backup, I cant save it to local "on the system" as you wrote. Could you please help me?
September 10, 20188 yr On 8/16/2018 at 6:30 AM, Anshu kumar said: Hi @lokdawg78, First of all, I would like to share that restoring Enpass 5 data directly from the cloud is not possible, you need to restore it with the backup file. Please follow these steps for restoring Enpass 5 data into Enpass 6. Step 1: Open Enpass 5 --> Take the backup of Enpass data and save it manually on the system. Step 2: Quit Enpass 6 (If running). Go to User Documents folder --> Rename Enpass6-Beta folder. Now Open Enpass 6. It will prompt you a welcome screen --> Select Backup file --> Browse to the backup of Enpass 5 and follow the instructions. Hope this helps! Hi @Anshu kumar, thanks for sharing this tutorial. I propably came a cross a new ?bug? -> cant restore on the same wifi network the backup files. The backup is smooth -> save to pc (no problem) but when I immediately open enpass 6 a try to restore. I cant load the backup and restore server.. I have to switch to another wifi network and then the restore page is working. Not sure if its bug in the app or not so I rather report thanks for your help and work! Kind regards Lukas
