September 8, 20188 yr Hi there, Reporting a bug for the taskbar icon. I am using Enpass 6 beta on Debian Linux Unstable/Sid with Budgie Desktop and the taskbar icon is huge causing the taskbar to stretch its height. Also, the main window upon system startup appears. Is there an option so that it always minimized to tray upon startup? Please advise. Thanks, Kan
September 8, 20188 yr Author Disregard the icon issue. There was a Budgie-desktop update this morning, and it was fixed upon reboot. I would still like to request the option to minimize to tray upon startup. Best, Kan
September 10, 20188 yr On 9/8/2018 at 5:54 PM, Kan said: Disregard the icon issue. There was a Budgie-desktop update this morning, and it was fixed upon reboot. I would still like to request the option to minimize to tray upon startup. Best, Kan The option is currently missing in the Linux build. Would also appreciate to have the option "Start minimized" back.
September 10, 20188 yr Hi @7Bit, Thanks for writing in. 3 hours ago, 7Bit said: The option is currently missing in the Linux build. Would also appreciate to have the option "Start minimized" back. I would like to share that if the option Open Automatically at startup is enabled in Enpass General setting then the app will be automatically minimized to the system tray with system startup. But currently, it's not behaving as expected and same has been noted as a bug to be fixed in next beta update. Thanks!
September 10, 20188 yr Author Also, would like to add, my original issue of the enpass6 icon in the taskbar being large has returned. I have to keep shutting down enpass, otherwise the icon is making my taskbar HUGE. Thanks.
September 11, 20188 yr Hi @Kan 21 hours ago, Kan said: Also, would like to add, my original issue of the enpass6 icon in the taskbar being large has returned. I have to keep shutting down enpass, otherwise the icon is making my taskbar HUGE. 1 I've noted it down and notified the dev team to look into it. Thanks for your co-operation.
September 12, 20188 yr 19 hours ago, Anshu kumar said: Hi @Kan I've noted it down and notified the dev team to look into it. Thanks for your co-operation. Please also note that the icon is generally not visible using Manjaro Linux with XFCE. Not at all.
