September 24, 20188 yr What is the process for deleting a vault when you have multiple vaults, can't seem to locate delete/remove vault anywhere?
September 24, 20188 yr Hi @Nev Thanks for writing in. Please follow these steps to remove Vault. Open Enpass --> Settings --> Vaults --> Open Vault which you want to remove --> Select the Menu Option --> Tap Remove Vault. Cheers!
February 12, 20215 yr Even though the User Manual for version 6.6.0 still stipulates the same procedure (https://www.enpass.io/docs/manual-desktop/vault-setting.html#:~:text=Remove Vault-,Click the options menu (3-dots) button and click,to ensure removing the vault.) I no longer see those 3 dots in the interface (see attached screenshot). Can someone clarify how this is supposed to work today?
February 15, 20215 yr Hi @gPaq, Thanks for writing in. To remove a vault, follow the steps as mentioned: 1. Go to Settings → Vaults → Select vault → Vault setting page will open → Click the options menu (3-dots) button and click Remove Vault. Note: There is no option to delete the primary vault.
