Unexpected Error at Startup
Hello,
I migrated from Windows 7 to Windows 10 with Enpass.
Enpass works after Installing it but refuses to start after that one time.
As soon as I try to start it, this popup appears:
And that's it.
I'm on Windows 10 Education 17134.286.
Enpass is on Version 5.6.9.
I can't install the UWP-Version because the Windows Store is disabled using Group Policies on my Laptop.
I also tried to use The portable version, but with no luck.
Any help would be apreciated.
Hello Again,
This issue exists for me now for almost a week and there's no sign of sombody trying to help me.
This is  really annoying because I have to keep my old laptop around to look up passwords I need.
I'm sorry for being rude, but I really want entpass to work on my laptop.
I just switched to It a few months ago and I don't feel like switching to a different password-mananger again.
Hi @Dekkia,
Sorry for the delay, it was an oversight.
Please follow these troubleshooting steps and let me know if the problem persists.
  • Uninstall Enpass from the Windows PC.
  • Run the registry editor (Hold Windows Key and R, then type in regedit)and navigate to the location as attached in the screenshot.
  • Delete Sinew Software Systems Folder.
  • Now install the Enpass again and it should work.
Hope this helps!
Thanks for your reply!
Now enpass works properly. Thank you!
