November 7, 20188 yr In Enpass 5.6.9 there are lines between each Field making it easier to find the correct Copy or Show/Hide button to the right of the username/password/url. See the attached image were i have marked those lines with green lines and compare it to how it looks for the same login in Enpass 6.0.0 (149). In the attached image the problem may not seem critical, but if i run Enpass 6.0.0 (149) in full screen mode on my 27 inch screen it becomes a problem since the UI by default move the Copy or Show/Hide button away from the Field. I want those lines between each Field in Enpass 6 since they are helpful to guide the end user. A side note: Note that the URL takes up much more screen real estate in Enpass 6.0.0 (149) compared to Enpass 5.6.9. Both version have the very same url in this login so i see no reason to why Enpass 6.0.0 (149) won´t show it as gracefully as Enpass 5.6.9 does. Edited November 7, 20188 yr by Roger
November 11, 20188 yr Hey @Roger, Thanks for sharing your feedback. I'll happy to forward it to the concerned desk for further improvement. Thanks!
