November 7, 20188 yr If i run Enpass 6.0.0 (149) at full screen on my 27-inch screen (2560x1440) and adjust the pane divider to the right and then Restore Down (Win+Down Arrow) the far right pane is lost. To get it back i must maximize Enpass and move back the right divider to the left and then Restore down. This is not the case with Enpass 5.6.9.
November 11, 20187 yr Hey @Roger, Thanks for reporting this issue. I've noted it down. Thanks for your co-operation.
