Application crash - Reproduce steps provided
I live in Sweden and we use the characters å, ä and ö often. If i try to attach a file, image or text file, with either å, ä and ö in the file name Enpass 6.0.0 (149) crash when i attempt to save the changes i made.
Steps to reproduce:
1. Download and unzip this zip file with four small png-files: https://1drv.ms/u/s!AtFsQF-l3dqLhMp5hpGTJgs2qjTs-g
2. Edit or add any item in Enpass 6 and click on the Add Attachement button.
3. Add one of the following files: Instållningar.png, Inställningar.png or Instöllningar.png
4. Click Save
Actual result:
Enpass 6 chrashes within seconds.
Expected result:
That i can add files with å, ä and ö in the file names, just the way i can do successfully in Enpass 5.6.9.
Additional info:
1. If you repeat the steps to reproduce it abowe and attach the file named Installningar.png and click Save Enpass 6.0.0 (149) won´t crash.
2. Windows reports the error you can find in the image attached to this forum post.
Hey @Roger
Thanks for sharing the details of the issue. Much Appreciated.:)
We have found the issue and a fix will be available in the next update.
Thanks!
