Chrome extension 6.0
Dear enpass team,
this morning my Chrome extension of Enpass was updated automatically to 6.0 and is no longer working with traditional win32 version:
Extension is showing message:
Quote
Extension is unable to connect with Enpass
You are using an older version of Enpass. The extension requires Enpass version 6.0.0 or later be installed first.
If I press update button and the download page of Enapss opens:
     Traditional Win32
     - Requires Windows 7 or later
     - Latest version: v5.6.9
Checking updates with desktop version, does not show any updates!
!!! Now I am unable to use Enpass with Chrome !!!
[EDIT 11/27/2018 - 7:22 AM]
Enpass extension is no longer available in Chrome web store. Link from intalled extension ends up in 404 error: Website not found
Edited by norlue
Update
Good morning,
I've the same problem over here. I usually use Enpass on a productive system so I can't switch over to your beta program. Is there any possibility to downgrade the Chrome plugin? Furthermore it seems that your extension page on the Chrome web store under https://chrome.google.com/webstore/detail/kmcfomidfpdkfieipokbalgegidffkal is missing. Can I download a functional version for your extension?
Regards,
Mew
Edited by mew
Hello, there,
I have the same problem. I would be happy about a solution.
Hey guys,
Sorry for the inconvenience.
There is some technical issue with our end which we have already fixed. So please update the Enpass extension and let me know if the problem persists.
Cheers!
Dear Anshu,
removed extension, reinstalled from Chrome web store (now available again) and this installs version 5.5.3
Running fine again! :-)
Thank you!
11 minutes ago, Anshu kumar said:
Hey guys,
Cheers!
Thank you, Anshu! :-)
Just a small question regarding this. I have installed the Windows win32 version from Microsoft Store instead of downloading any msi-setup file here. Will the win32 version installed from the store be automatically updated as any other store app?
Still not working for me with Chrome, but works fine with Firefox.
Edited by Pete
Decided to try Enpass today if it could replace my 1Password subscription. I installed the Bridged version (I think) and not the 10dollar UWP one. Installed the Chrome extension. Now when I try to click the extension it just says i need to update my Enpass desktop app but there is no updates available.
The chrome extension seems to be version 5.X and the Enpass app is 6.X
 Hey guys,
I would like to share that Chrome web store does not allow two different channels (beta and production) for the same extension, so we have to publish beta as a separate extension. Please install the beta Enpass browser extension for Chrome browser from this link and let me know if the problem persists.
Thanks!
17 hours ago, Anshu kumar said:
 Hey guys,
Thanks!
I know that, I've been using the Beta for awhile now (probably the day it was released). It was working just fine until the latest Chrome version got updated, now it won't connect. I've tried uninstalling reinstalling etc still nothing. During the connection attempt, it loads the program, then error it couldn't connect. I'm not the only one this is happening to either.
Can confirm the new update for the Enpass 6 Chrome extension is broken.
Chome Extension Version:
6.0.0.56
Software Version:
Enpass Beta 6.0.0 (149)
@Anshu kumar
Windows: 10 1803
Enpass: 6.0.0 (149)
Extension: 6.0.0.56
Chrome: 70.0.3538.110
Edited by Pete
11/30/2018 - The chrome extension connection is still broken.
@Pete I like your layout of information.
@Anshu kumar Version info below.
Windows: 10.0.17134
Enpass: 6.0.0 (149)
Extension: 6.0.0.56
Ok, I managed to get it connected with Chrome, updated the Windows program from 149 to 198. But please be careful (I must stress this), you might lose data if you used custom categories in the past, as it's a premium feature now.
Windows: 10.0.17134
Enpass: 6.0.0 (149)
Extension: 6.0.0.56
Please install the latest beta version of the Enpass app from this link and check.
Thanks!
The beta enpass extension is now also working for me under vivaldi. Thanks.
  • 4 weeks later...
The beta fixes this issue for me as well; but I do not want to use the beta forever. Could you give us an update when the stable version is fixed? @Anshu kumar
