November 28, 20188 yr Hi, I cannot use any browser extension on my computer anymore i keep getting "Enpass assistant is unable to connect with the Enpass app" What have I done to try and solve this in chrome Reinstall Chrome plugin Enable / disable browser plugin in enpass Reinstall Chrome Reinstall Enpass Remove “.sync”and “.settings” in my enpass folder Reboot Full cleanup of enpass and chrome including manual cleanup ( Registry entries, folders, appdata...) Tried Edge but i get the same error... Enpass desktop version: 6.0.0 (149) Chrome Plugin: 6.0.0.56 Any advice on how to solve this?
November 28, 20188 yr I have the exact same issue as Michiel, as well as having done basically the exact same steps to resolve the issue. According to the debug tools for the extension, I am getting repeated messages about failure to connect via the websocket: I've also gone ahead and emailed the betabugs@enpass address, but posting here to get more visibility. I also noted that in this forum that there is another thread about the extension not working for Mac originally posted in September, but now has a couple of other users posting within the last week regarding issues again. It appears that with the latest push of the browser extension for enpass that it broke connectivity.
November 28, 20188 yr @Meister - I can confirm that that resolved the issue for myself. I believed my enpass was up to date since when checking for updates it was saying "Up to date". From the release notes of the new release though, it appears that this was probably intentional since you had to make a backup of your data due to the change in storage/sync location between the versions. Wish they would have released some stub update that would've just run and told you what to do at least, but I'm finally working again.Thanks! Edited November 28, 20188 yr by tostringtheory
November 28, 20188 yr Author @Meister, this did solve my issue but created a new one that my sync doesnt work with onedrive. My items from my pc are not synced to my android I found the problem the new beta uses "apps\enpass" folder for sync and the android beta is looking at "apps\enpass beta" Edited November 28, 20188 yr by Michiel
November 28, 20188 yr 1 hour ago, Michiel said: @Meister, this did solve my issue but created a new one that my sync doesnt work with onedrive. My items from my pc are not synced to my android I found the problem the new beta uses "apps\enpass" folder for sync and the android beta is looking at "apps\enpass beta" Looks like you are still using the old android beta. You need to be a beta tester and install the app from there, the old Beta app is not compatible. Edited November 28, 20188 yr by Meister
November 29, 20188 yr Author For the moment the version on my android device is the beta version from 28/10 -- 6.0.0.75
November 29, 20188 yr 5 minutes ago, Michiel said: For the moment the version on my android device is the beta version from 28/10 -- 6.0.0.75 Yes, that's the old beta and is not compatible for syncing.
November 29, 20188 yr Author 24 minutes ago, Meister said: Yes, that's the old beta and is not compatible for syncing. ok, and how do i get the new beta, because when i go to google play and beta there are no updates available for Enpass
