January 5, 20197 yr Hi there, since upgrading to v6, Autofill is working but very slowly. It takes a least around 15-20 seconds before the dialog pops ups System information: macOS 10.14.2, Enpass 6.0.2 (292), Safari browser, synchronization is done via iCloud Any clues why this is happening? Appreciate the help!
January 6, 20197 yr At least you do have autofill. I alway have to choose the entry because Enpass pops up Version 6 is a total mess, is there a way to downgrade?
January 10, 20197 yr When I want to fill in a login by activating the assistant (Safari on Mac, latest version), it often takes about 5 seconds until the assistant window appears. In the meantime, I do not get any visual feedback of my action, so I don't know if my action has been registered at all by the computer. Pretty confusing.
July 22, 20197 yr Hey @nonchiedercilaparola, Sorry for the trouble you are going through. Can you please let me know are you facing this problem after the recent update. Also, please share some more info so that we can help you better. On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Number of vaults and items in Enpass? Which cloud services are you using Enpass? Thanks for your co-operation.
July 24, 20197 yr @Anshu kumar Might be the same / similar issue as discussed here: @nonchiedercilaparola As a workaround until this issue is fixed, try to restart Enpass when you are facing this problem again.
July 25, 20197 yr Hey guys, Our dev team is working on this issue and hopefully a fix will be available soon. Thanks for your co-operation.
