Printing
Hey @khemm66
In the desktop version of Enpass already have the Print feature. You can check under the ≡ menu from the toolbar -->  select File →Print.
Hope this helps!
Thanks for your reply-
When I do that it says that no printer is found--BUT my wireless Printer is connected because I am able print other things--Any suggestions with that?
  • 2 weeks later...
I have the same problem with the desktop app on OSX, if I am trying to print out the whole tresor for hardcopy, an error message "printer not found" is shown and I have no possibility to set a printer on the enpass app. thanks for fixing this bug.
cheers Philippe
  • 4 weeks later...
I have the same problem with the desktop app on OSX MOJAVE 10.14.3 , if I am trying to print out the whole tresor for hardcopy, an error message "printer not found" is shown and I have no possibility to set a printer on the enpass app. thanks for fixing this bug.
Miklos
On 1/24/2019 at 12:37 PM, Anshu kumar said:
Hey @khemm66,
I have filed a bug for this and notified the dev team to look into it.
Thanks for your co-operation.
@Anshu kumar what about the status about this bugfix? any news? thanks and best regards
This is so frustrating--Still can't Print--Says "No Printer Found"  Please fix it soon
