Hold Generated Passwords in a temporary store until save
I have Enpass set to clear the clipboard every 30s (default).
When updating the password for a site I sometimes encounter a situation in which the generated password is not accepted.  Reasons could be that certain characters are not acceptable or there is a password length mismatch.
Can Enpass retain the original password until the user confirms that the old password has been replaced.
This function can also be useful to retain a password history function.
Hope this helps
Hey @chribonn,
Thanks for writing in.
I would like to let you know that when you generate password through Enpass password generator (Either from App or Enpass browser extension), it keeps a record of the password that you used, along with their respective timestamps. For more details please refer our user manual.
Hope this helps!
I confirm that:
1. You can follow the history of generated passwords as described in the link you provided
2. If you have a data card open in the client (not the web extension popup) and you right click on a password property you can see the password history of that field.
Thank you @Anshu kumar.
