February 10, 20197 yr Unfortunately Enpass still doesn't work in the combination with Firefox, Windows 10 and Joomla or WordPress. The login fields are still blanked out and I have to fill in the fields manually. I was hoping that the latest update would solve the problem but the problem has not been solved jet.
February 12, 20197 yr Hey @deroderuiter Sorry for the trouble you are going through. We have tested this issue in our lab and were unable to reproduce it. If possible, can you please share a small video of the issue at support@enpass.io so that we can investigate further. Thanks for your co-operation.
February 13, 20197 yr Author I have sent you the video you requested. In the video I noticed that Enpass did sent the userid and password before I could fill the TOTP, however, In the settings, I blacked out "Automatically Login After Filling Details".
February 13, 20197 yr Hey @deroderuiter, Thanks for sharing the video. I have noted down this issue in the tracker and notified the dev team to look into it. Till then please co-operate with us.
March 13, 20197 yr Author Since the problem has not been solved yet I switched to Bitwarden. Bitwarden runs without any problem. Kind regards, Rob de Ruiter
