March 14, 20197 yr Hello, I was composing an email and wanted to enter the € (Euro) symbol into the text. But when I pressed <AltGr>+<E> (same effect than pressing <Ctrl>+<Alt>+<E>), the Enpass Assistant is shown. I had to close Enpass to be able to enter the € character. Of cause I can adjust the hotkey manually in the settings. But IMHO the default hotkey should not be <Ctrl>+<Alt>+<E>. I think this hotkey is present in the whole European Union (but I an not 100% sure). Best regards OLLI Edited March 14, 20197 yr by OLLI_S
September 21, 20197 yr I totally agree. The default hotkey shouldn't be "e". Or CTRL+ALT+* could be different from AltGr+** (two different hotkey values) Also the general settings don't tell you that CTRL+ALT+* is the same hotkey. They don't mention AltGr at all.
May 22, 20206 yr Hey, just came here to post this. I got the same problem. I use ctrl+alt+e as the global hotkey, because I think it makes sense, since I open Enpass in the browser with ctrl+e. According to this documentation https://docs.microsoft.com/en-us/dotnet/api/system.windows.forms.keys?redirectedfrom=MSDN&view=netcore-3.1, the key is named RMenu. Maybe the developers can look at this and differentiate those keys (ctrl+alt vs altgr) on keyboards, that have it?
May 22, 20206 yr Hey All, Thanks for writing to us. I would like to share that you can customize the keyboard shortcut or hotkey as per your convenience. To do so, please refer to this link. Thanks.
