March 27, 20197 yr I want the autofill feature to detect/fill logins by domain. Currently the detection includes subdomain, but some sites use the same account login across their domain with different subdomains. Thanks.
March 28, 20197 yr Hey @jakejohn , Thanks for writing in. Well, in this case, you can try Disabling "Match URL Hostname" in Enpass Autofill settings. Or you can add full URLs in that particular item. Hope this helps!
September 3, 20197 yr +1 Here @Anshu kumar This one is not working as expected. It would be great when visited *.example.com to list everything related, every subdomain.
September 4, 20197 yr Hi @Vuk Please share the following details so that we can check further. On which device (along with OS version) are you using Enpass? Which Enpass version are you using? Thanks for your co-operation.
September 16, 20197 yr On 3/27/2019 at 10:27 AM, jakejohn said: I want the autofill feature to detect/fill logins by domain. Currently the detection includes subdomain, but some sites use the same account login across their domain with different subdomains. Thanks. I just played around with this and I think I have a solution. By default, the field "Website" is in the entry and it looks like you cannot add another field of this type. However, you can add multiple "URL" fields and they should behave in the same way as the "Website" field. I tested it on one of my password entries and it worked fine everywhere I was able to use it.
