Enpass can't run using only iGPU ?
Hi there,
I have a problem with my MacBook Pro GPU, that causes some Kernel Panics.
I'm using a small tool for avoiding this problem : it tells the computer to keep using iGPU and to not use GPU. (gfxCardStatus)
Unfortunately, when Enpass is launched I can't force using iGPU because of Enpass.
Maybe Enpass uses GPU as soon as it is present, and do not let other apps tell him what to do.
Do you think that could be the case one day ? What I mean is, do you think it makes sense that Enpass can run on iGPU even when a GPU is present ?
Thank you very much.
André
Hey @d1abo
I have noted down this issue in the bug tracker and notified the dev team to look into it.
Thanks for your co-operation.
  • 4 weeks later...
Is this issue fixed ? It seems to me that my MBP is not switching to dGPU now when openning and when my computer is set to use only iGPU if possible.
