April 7, 20197 yr Friends, The Enpass Chrome plugin was working on test (leaked) build of Edge on Chromium version 111 (which is often called Edgium). I just upgraded to 19H1 on the slow ring (presumably the Release Preview coming next week). Now I am getting an error as below. I will continue to test and hope that the Beta Edge on Chromium comes out soon, and I will go back to Brave with the Enpass extension until I can get the stable Edgium. Browser requesting the data is not code signed. You can share the following diagnostics with us at support@enpass.io. code : 3 origin : chrome-extension://kmcfomidfpdkfieipokbalgegidffkal path : C:\Users\jeffrey\AppData\Local\Microsoft\Edge\Application\msedge.exe port : 49964 server_port : 10391 Just passing along in case it helps. Not sure where the
April 10, 20197 yr Hey @JeffB, Thanks for reporting this issue. Our dev team is working into it. Till then please co-operate with us.
April 10, 20197 yr Author The Enpass extension from the Google Web Store is working very well on both the Dev and Canary release builds. I think the Enpass extension in the Microsoft Extension store is still V5, but I haven't checked in a couple of days.
April 12, 20197 yr Hi All, The problem has been identified, and we are currently working on it. An update with the fixes will be submitted to the Store soon. Meanwhile, you can make Enpass extension working on Edge by disabling the "Authorized browser with verified code signature only" option in Enpass Browser setting. Thanks for your co-operation.
June 24, 20197 yr Is there a fix for this yet? I'm encountering a similar issue using the Chrome store extension with un-googled Chromium running on Mac OS Mojave. The workaround described above works but I would like to know how to fix the signing issue. Is this actually an Enpass issue? It seems like a Chromium problem. Edited June 25, 20197 yr by stevemckay
June 26, 20197 yr Hi @stevemckay, Can you please share the browser name and it's version so that we can check it from our end. Thanks!
