Issue with autofill automatically adding new URL entries
I use the F5 Access VPN client on my iOS device to connect to my work network.  I have a "generic" URL entry for VPN endpoint but every time I access the site the URI is dynamic (it includes a nonce value).  As a result, the Enpass iOS client adds a "URL" entry to the "generic" URL entry, resulting in a whole bunch of useless entries being added.  Is there a way to stop / correct this behaviour?
Edited by ChrisSutcliffe
Thanks for the reply @Ankur Gupta, I hope to see the fix soon!  Unfortunately the nonce value is in the URI string, not the domain name, so the setting you mention doesn't help.
  • 6 months later...
This issue has been fixed for a while - you now have the option to add and entry or simply Autofill when you Autofill a password entry.
