May 29, 20197 yr Hi all, I am running Linux Mint with Enpass 6.0.6 (323). Enpass does not sync with Google Drive (it works on my Android) and displays error-message 404007. Can someone please help? thx Edited May 29, 20197 yr by qvarq spelling
May 30, 20197 yr Hi @qvarq, Sorry for the trouble you are going through. For quick troubleshooting please re-connect the Google Drive from Enpass settings. If the problem persists, please let me know are you using the proxy/firewall. Thanks for your co-operation.
June 5, 20197 yr Author Thanks! I actually had blocked the google API in my hosts file on my local machine. It was dnsmasq.config where I had to manually remove the URL of the Google API. I then could easily sync with Google Drive. I love enpass ;-)
