June 9, 20197 yr Can anybody tell me why i can not move the columns to the right ? I want to enlarge the space in the column "items" and the column "titles" . There is a icon visible when i place y mouse on the borderline......but i will not move? Is this a hidden option or something else? Are there Enpass users how can move and create more ore less space in the fields?
March 22, 20206 yr Those two columns are way too small! They should be expanded to the right, where there is plenty of room. I like Enpass a lot, and I would gladly pay/donate plenty for it, but I couldn't consider using it with those columns so small.
March 22, 20206 yr Author As you can see my post is already old,....but i also send an email to support fot this subjec. These lines are ridiculous when they can not be moverd! I have a paid version with errors and nothings ware i can see that i am using an payed version, but also ....now answer from support. Questions about wifi sync, witch the promised al long time ago....now answer from support. I am loosing my feeling about this program!
March 22, 20206 yr You're sure right, Bout. Nobody is listening to us or cares what we say. I had a good feeling about Enpass for a long time, and I have been waiting until it is truly usable before I take it seriously and actually begin to use it. It seems as if a remedy for the skinny columns, which are unusable, may be a long time coming. Good luck with your other problems, too!
March 23, 20206 yr Hi @Guffee and @Bout, Sorry for the unpleasant experience. I would like to share that WiFi sync feature is already in our road-map but will take some time. I've shared the feedback with the development team though. Thanks.
