June 20, 20197 yr I'd first like to register some frustration on how poorly the version 5 to 6 transition (and dropping of platforms) was communicated. I've been a long time user of both the iOS, UWP and WPF versions of the application for many years and never received a single piece of communication about any of these changes. While I understand the reasoning behind them it's left me in a awkward position. Having three different apps (iOS, UWP and WPF) over five devices I didn't notice the lack of sync between the two devices stuck on version 5 (in fact they happily synced between each other) and the other three. This has left me in a "split brain" scenario where I have a set of changes in the version 6 database in OneDrive and another set of changes in the version 5 file. I need a strategy to reconcile these changes into the version 6 database. As far as I can tell the only format the version 5 UWP app will export is the backups in walletx format. I cannot see any way in the version 6 WPF app to restore or import this format of file. What is the best way to get back to single version without losing my data?
June 24, 20197 yr Hi @Nigel Sampson, Sorry for the trouble you are going through. I would like to share that since Enpass 6 is based on a new architecture, it will only sync with Enpass 6, and not with previous versions. So, to test the sync functionality, you’d need to install the Enpass 6 on your other device as well. Thanks!
August 16, 20197 yr Dear Anshu, That is exactly Nigels point (and mine too). Enpass does not support UWP anymore, so how can the current UWP-Enpass app (5.5) use the new Enpass 6 database. Regards, Toine
